Salta al contenuto principale
How to Add a Hole in a Leather Belt
Cosa ti serve
  1. How to Add a Hole in a Leather Belt, How to Add a Hole in a Leather Belt: passo 1, immagine 1 di 1
    • Make sure the leather belt is clean by wiping it down with water and drying it before working on it beforehand to get rid of any excess dirt or grime.
  2. How to Add a Hole in a Leather Belt: passo 2, immagine 1 di 1
    • Find a flat and durable surface to work on, preferably a wooden work table. If that’s not available, then use a good sized wooden block to work on.
  3. How to Add a Hole in a Leather Belt: passo 3, immagine 1 di 1
    • Using a measuring tape, measure the distance between each of the existing holes to figure out the distance to place your new hole.
  4. How to Add a Hole in a Leather Belt: passo 4, immagine 1 di 1
    • Mark where you want the hole with either a pen or indent using the pin punch. Mark as many as you see fit before continuing onto the next step.
  5. How to Add a Hole in a Leather Belt: passo 5, immagine 1 di 1
    • Align the pin punch where you marked the hole.
    • Make sure to tighten the grip on the pin before hammering onto the marked area. Continue this for all the other hole marks.
  6. How to Add a Hole in a Leather Belt: passo 6, immagine 1 di 1
    • Push the pin all the way through the hole to make sure the hole is fully formed.
  7. How to Add a Hole in a Leather Belt: passo 7, immagine 1 di 1
    • Clean off any stray leather bits left from the hole placement using a razor blade.
Conclusione
Once you complete all your steps, make sure to congratulate yourself on your new belt! Now you can hold up anything you need without any issues.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 266
