Salta al contenuto principale
How To Remove Rust From Old Tools
Cosa ti serve
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, immagine 1 di 2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, immagine 2 di 2
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: passo 2, immagine 1 di 2 How To Remove Rust From Old Tools: passo 2, immagine 2 di 2
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: passo 3, immagine 1 di 3 How To Remove Rust From Old Tools: passo 3, immagine 2 di 3 How To Remove Rust From Old Tools: passo 3, immagine 3 di 3
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: passo 4, immagine 1 di 3 How To Remove Rust From Old Tools: passo 4, immagine 2 di 3 How To Remove Rust From Old Tools: passo 4, immagine 3 di 3
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: passo 5, immagine 1 di 1
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
Conclusione
Altre 8 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
90.075 Reputazione
89 Guide realizzate
2 Commenti
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Replica
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 128
Tutti i Tempi: 4,481
