Salta al contenuto principale
How To Install Universal Fit LED Daytime Running Lights
Cosa ti serve
  1. How To Install Universal Fit LED Daytime Running Lights, Philips Style LED Daytime Running Lights Upgrade: passo 1, immagine 1 di 1
    • Insert the wire into the bracket.
  2. How To Install Universal Fit LED Daytime Running Lights: passo 2, immagine 1 di 1
    • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
  3. How To Install Universal Fit LED Daytime Running Lights: passo 3, immagine 1 di 1
    • After mounting the bracket, you can lock the LED daytime running light on the bracket.
  4. How To Install Universal Fit LED Daytime Running Lights: passo 4, immagine 1 di 2 How To Install Universal Fit LED Daytime Running Lights: passo 4, immagine 2 di 2
    • Connect the wires and route the wires up and near the fuse box.
    • Use zip ties to tie the wire along the bumper.
  5. How To Install Universal Fit LED Daytime Running Lights: passo 5, immagine 1 di 2 How To Install Universal Fit LED Daytime Running Lights: passo 5, immagine 2 di 2
    • Find the ACC in your fuse box and tap the red wire there.
    • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
    • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
  6. How To Install Universal Fit LED Daytime Running Lights: passo 6, immagine 1 di 1
    • Tap the black wire to battery negative.
  7. How To Install Universal Fit LED Daytime Running Lights: passo 7, immagine 1 di 3 How To Install Universal Fit LED Daytime Running Lights: passo 7, immagine 2 di 3 How To Install Universal Fit LED Daytime Running Lights: passo 7, immagine 3 di 3
    • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
Conclusione
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
Altre 21 persone hanno completato questa guida.
Eric Wu
Membro da: 01/21/15
3.357 Reputazione
23 Guide realizzate
11 Commenti
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
http://optixautolabs.com/
Calvin Macaraeg - Replica
Useful info. Thanks
grant.edson - Replica
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
steve finlayson - Replica
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
i cry when i wii - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 127
Tutti i Tempi: 93,382
