Salta al contenuto principale
How To Hem Pants With Double-Sided Fabric Tape
Cosa ti serve
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: passo 1, immagine 1 di 1
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: passo 2, immagine 1 di 1
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: passo 3, immagine 1 di 1
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: passo 4, immagine 1 di 1
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: passo 5, immagine 1 di 1
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: passo 6, immagine 1 di 1
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: passo 7, immagine 1 di 1
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: passo 8, immagine 1 di 1
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: passo 9, immagine 1 di 1
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: passo 10, immagine 1 di 1
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: passo 11, immagine 1 di 1
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: passo 12, immagine 1 di 1
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
Conclusione
You don't need a sewing machine to hem a pair of overly long pants.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 55
Tutti i Tempi: 255
