Salta al contenuto principale
How To Fix a Torn Book Page
Cosa ti serve
  1. How To Fix a Torn Book Page, How To Fix a Torn Book Page: passo 1, immagine 1 di 1
    • Lay out all of the equipment needed for the repair.
  2. How To Fix a Torn Book Page: passo 2, immagine 1 di 1
    • Place one piece of wax paper behind the torn page.
    • The wax paper is used to protect the other pages from the glue.
  3. How To Fix a Torn Book Page: passo 3, immagine 1 di 1
    • Be very careful in aligning the torn piece with the page, as realignment after gluing will be difficult.
    • Make sure to align the torn pieces precisely. Placing them too closely or too far apart may create an issue in reading the pages later.
    • Align the torn pieces, so they connect the images/text accurately and neatly.
    • You may use a clamp to hold the torn pieces together to make gluing easier.
  4. How To Fix a Torn Book Page: passo 4, immagine 1 di 3 How To Fix a Torn Book Page: passo 4, immagine 2 di 3 How To Fix a Torn Book Page: passo 4, immagine 3 di 3
    • Do not apply too much glue, only enough to evenly cover the tear between the page and the torn piece.
    • Remove any excess glue to prevent the pages from sticking to the wax paper.
    • Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
    • Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
  5. How To Fix a Torn Book Page: passo 5, immagine 1 di 1
    • Place the second sheet of wax paper on top of the page you just glued.
    • Be careful when placing the wax paper on top of the wet glue. Moving the wax paper around will make the glue smear.
  6. How To Fix a Torn Book Page: passo 6, immagine 1 di 1
    • Wrap the closed book with several rubber bands to squeeze and compress during drying time.
  7. How To Fix a Torn Book Page: passo 7, immagine 1 di 2 How To Fix a Torn Book Page: passo 7, immagine 2 di 2
    • You can also use several books or other heavy items to add extra weight.
  8. How To Fix a Torn Book Page: passo 8, immagine 1 di 2 How To Fix a Torn Book Page: passo 8, immagine 2 di 2
    • Let the glue dry for 6 hours minimum to ensure that it dries completely.
    • Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Un commento
Thanks for article!
Alex White - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 16
Ultimi 7 Giorni: 77
Ultimi 30 Giorni: 347
Tutti i Tempi: 9,069
