Salta al contenuto principale
How To Fix A Broken Makeup Brush
Cosa ti serve
  1. How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: passo 1, immagine 1 di 2 How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: passo 1, immagine 2 di 2
    • Remove excess glue on the handle and the base of the brush using a nail file.
  2. How To Fix A Broken Makeup Brush: passo 2, immagine 1 di 1
    • Use the hot glue gun to apply glue to the inside base of the brush where the handle is attached.
    • Be cautious of the high temperature of the glue and gun when handling.
  3. How To Fix A Broken Makeup Brush: passo 3, immagine 1 di 1
    • Slowly place the brush head onto the handle and apply pressure for 15 seconds.
  4. How To Fix A Broken Makeup Brush: passo 4, immagine 1 di 1
    • Remove excess glue from the brush using a paper towel.
  5. How To Fix A Broken Makeup Brush: passo 5, immagine 1 di 1
    • Let the glue dry for 2-3 minutes to be sure it is securely attached.
Linea Traguardo
Shanae Swack
Membro da: 02/23/16
403 Reputazione
1 Guida realizzata
Texas Tech, Team 26-4, Rauch Spring 2016 Membro di Texas Tech, Team 26-4, Rauch Spring 2016
TTU-RAUCH-S16S26G4
3 Membri
1 Guida realizzata
Un commento
Amazing!!! Thanks a lot.
Amal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 6,022
