Salta al contenuto principale
Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement
Cosa ti serve
  1. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement, Electrochemical Sensors: passo 1, immagine 1 di 1
    • Confirm which sensor you are intending to replace. Make note of it.
    • Nitrile gloves should be worn for the entire procedure.
  2. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 2, immagine 1 di 2 Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 2, immagine 2 di 2
    • Place the monitor face down on a clean surface.
    • Use the Phillips #0 screwdriver to remove the single 3 mm Phillips screw on the belt clip.
  3. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 3, immagine 1 di 1
    • Starting at the bottom of the case, pull the outer case away from the main body of the monitor.
    • Continue pulling out and away until the entire outer case has been removed.
  4. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 4, immagine 1 di 1
    • With the Phillips #0 screwdriver, remove all four 3 mm screws from the rear pump/sensor cover.
  5. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 5, immagine 1 di 1
    • Remove the outer pump/sensor housing cover and set it aside.
  6. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 6, immagine 1 di 1
    • Carefully grip and twist the outer edge of the sensor to remove the sensor from its insertion point.
    • Be careful not to twist too aggressively as this could damage the sensor attachment point in the monitor.
  7. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 7, immagine 1 di 3 Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 7, immagine 2 di 3 Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 7, immagine 3 di 3
    • Grip the replacement sensor on the outer edge.
    • Insert the new sensor in a straight downward orientation.
    • Be careful to line up the prongs with their insertion/attachment point in the monitor.
  8. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: passo 8, immagine 1 di 1
    • Reassemble the unit in reverse order.
    • After reassembly, power the unit on to ensure that the monitor recognizes the new sensor.
    • Calibrate the sensor per the manufacturer's instructions.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 43
Tutti i Tempi: 818
