Salta al contenuto principale
HP iPAQ h4155 button panel replacement
Cosa ti serve
  1. HP iPAQ h4155 button panel replacement, Battery: passo 1, immagine 1 di 1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 button panel replacement: passo 2, immagine 1 di 1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 button panel replacement: passo 3, immagine 1 di 1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 button panel replacement, Back Case: passo 4, immagine 1 di 1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 button panel replacement: passo 5, immagine 1 di 1
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 button panel replacement: passo 6, immagine 1 di 2 HP iPAQ h4155 button panel replacement: passo 6, immagine 2 di 2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 button panel replacement: passo 7, immagine 1 di 1
    • Remove the back case.
  8. HP iPAQ h4155 button panel replacement, Face Plate: passo 8, immagine 1 di 1
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 button panel replacement: passo 9, immagine 1 di 2 HP iPAQ h4155 button panel replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 button panel replacement: passo 10, immagine 1 di 2 HP iPAQ h4155 button panel replacement: passo 10, immagine 2 di 2
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 button panel replacement: passo 11, immagine 1 di 1
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 button panel replacement, JoyPad buttons: passo 12, immagine 1 di 1
    • Remove the 4 screws along the bottom of the faceplate
    • They are #00 Philips head screws
  13. HP iPAQ h4155 button panel replacement: passo 13, immagine 1 di 2 HP iPAQ h4155 button panel replacement: passo 13, immagine 2 di 2
    • Once removed you can easily separate the keys from the body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 458
