Salta al contenuto principale
HP EliteDesk 800 G4 Solid State Drive Replacement
Cosa ti serve
  1. HP EliteDesk 800 G4 Solid State Drive Replacement, Solid State Drive: passo 1, immagine 1 di 2 HP EliteDesk 800 G4 Solid State Drive Replacement, Solid State Drive: passo 1, immagine 2 di 2
    • Loosen the thumb screw on the back of the PC.
  2. HP EliteDesk 800 G4 Solid State Drive Replacement: passo 2, immagine 1 di 2 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Slide the panel forward (away from the screw) until it is detached from the machine.
    • Lift the panel up to remove it.
    • The front bezel of the device is attached to the access panel and will also be removed during this step.
  3. HP EliteDesk 800 G4 Solid State Drive Replacement: passo 3, immagine 1 di 3 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 3, immagine 2 di 3 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 3, immagine 3 di 3
    • Lift the storage cage lever and remove the storage drive from the cage.
  4. HP EliteDesk 800 G4 Solid State Drive Replacement: passo 4, immagine 1 di 3 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 4, immagine 2 di 3 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 4, immagine 3 di 3
    • Remove the two 12 mm screws near the front of the machine using a T55 Torx screwdriver.
    • Lower the cage lever.
  5. HP EliteDesk 800 G4 Solid State Drive Replacement: passo 5, immagine 1 di 2 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 5, immagine 2 di 2
    • Slide the cage forward and then up to remove it from the slots that secure it to the chassis.
    • Gently flip the storage cage over and rest it down in order to access the solid-state drive.
    • Be very careful to not pull too harshly on the locking bar, which connects the storage cage to the motherboard. This could potentially damage the machine.
  6. HP EliteDesk 800 G4 Solid State Drive Replacement: passo 6, immagine 1 di 3 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 6, immagine 2 di 3 HP EliteDesk 800 G4 Solid State Drive Replacement: passo 6, immagine 3 di 3
    • Remove the single 4 mm screw that secures the solid-state drive using a Phillips #2 screwdriver.
    • Allow the solid-state drive to rise into a tension position.
  7. HP EliteDesk 800 G4 Solid State Drive Replacement: passo 7, immagine 1 di 1
    • Take the solid state drive by the edges and gently pull it from its slot.
    • To replace the solid state drive, align the slot in the drive with the key on the chassis and gently slide it back into its slot at an angle.
Conclusione
Follow the guide in reverse order to replace the rest of the parts that have been removed.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 195
Tutti i Tempi: 2,636
