Salta al contenuto principale
Goodman Furnace Blower Motor Replacement
Cosa ti serve
  1. Goodman Furnace Blower Motor Replacement, Opening the Unit: passo 1, immagine 1 di 3 Goodman Furnace Blower Motor Replacement, Opening the Unit: passo 1, immagine 2 di 3 Goodman Furnace Blower Motor Replacement, Opening the Unit: passo 1, immagine 3 di 3
    • Ensure all power cables are disconnected from the unit and/or wall prior to attempting this guide.
    • Gloves are highly recommended to avoid injuries from any sharp edges.
    • Unscrew the two screws located on the rear side of the unit.
    • Remove the doors and set them aside.
    • A 3/8" screwdriver will be the easiest method of completing this step.
  2. Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: passo 2, immagine 1 di 3 Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: passo 2, immagine 2 di 3 Goodman Furnace Blower Motor Replacement, Removing Electrical Connections: passo 2, immagine 3 di 3
    • It is strongly advised that you take a picture of the wire configuration prior to removal for reference when connecting the new motor.
    • Disconnect the brown wire from the top of the motor.
    • Disconnect the second brown wire from the bottom of the unit.
    • Remove the white, blue, red, orange, and black wires from the controller board.
  3. Goodman Furnace Blower Motor Replacement, Removing the Motherboard Screws: passo 3, immagine 1 di 2 Goodman Furnace Blower Motor Replacement, Removing the Motherboard Screws: passo 3, immagine 2 di 2
    • Unscrew both screws connected the motherboard to the cylindrical motor container.
    • The screws are located on top and bottom sides of the plate holding the motherboard.
  4. Goodman Furnace Blower Motor Replacement, Removing the Motor Container: passo 4, immagine 1 di 2 Goodman Furnace Blower Motor Replacement, Removing the Motor Container: passo 4, immagine 2 di 2
    • Unscrew the cylindrical motor housing from the unit.
    • There are two screws located at each side of the top corner of the container.
    • Grab the motor container with two hands and pull it out of the unit.
    • Place the motherboard to the side.
  5. Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: passo 5, immagine 1 di 3 Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: passo 5, immagine 2 di 3 Goodman Furnace Blower Motor Replacement, Removing the Motor from the Housing: passo 5, immagine 3 di 3
    • Turn the motor container on its side, with the wires pointing up.
    • Unscrew the 3 screws attaching the motor to the housing.
    • Take the yellow wire out of the screw.
    • Use a wrench to remove the bolt from the shaft of the motor, located on the opposite side.
    • If rust has accumulated on the motor shaft, you may wish to use sandpaper to remove it to make the motor easier to remove.
    • Firmly grasp the motor from the side where the screws were previously located and pull to remove it.
    • The white label on the side of the motor contains the model number of the blower motor which you may use as a reference when ordering a replacement, if necessary.
  6. Goodman Furnace Blower Motor Replacement, Inserting the Replacement Motor: passo 6, immagine 1 di 2 Goodman Furnace Blower Motor Replacement, Inserting the Replacement Motor: passo 6, immagine 2 di 2
    • Insert the new motor into the motor housing.
    • Ensure the wires are at the front of the assembly.
    • Tighten the bolt at the shaft of the motor that you removed in the previous step.
    • You may wish to get the bolt started with your hands, and finish tightening with the wrench.
    • Ensure the flat surface is aligned with the screw hole prior to tightening with the wrench.
  7. Goodman Furnace Blower Motor Replacement, Reassembly Tips: passo 7, immagine 1 di 1
    • Ensure the fan blades are freely spinning prior to continuing.
    • When assessing the fan blade, ensure you either keep your hands flat or wear gloves to avoid injury.
    • Utilize your reference photo when rewiring the unit.
Conclusione
Ryan W
Membro da: 11/30/23
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 81
Tutti i Tempi: 241
