Salta al contenuto principale
Golf Club Shaft Replacement
Cosa ti serve
  1. Golf Club Shaft Replacement, Shaft: passo 1, immagine 1 di 1
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: passo 2, immagine 1 di 3 Golf Club Shaft Replacement: passo 2, immagine 2 di 3 Golf Club Shaft Replacement: passo 2, immagine 3 di 3
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: passo 3, immagine 1 di 2 Golf Club Shaft Replacement: passo 3, immagine 2 di 2
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: passo 4, immagine 1 di 1
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: passo 5, immagine 1 di 3 Golf Club Shaft Replacement: passo 5, immagine 2 di 3 Golf Club Shaft Replacement: passo 5, immagine 3 di 3
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: passo 6, immagine 1 di 3 Golf Club Shaft Replacement: passo 6, immagine 2 di 3 Golf Club Shaft Replacement: passo 6, immagine 3 di 3
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: passo 7, immagine 1 di 3 Golf Club Shaft Replacement: passo 7, immagine 2 di 3 Golf Club Shaft Replacement: passo 7, immagine 3 di 3
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Linea Traguardo
George Bassili
Membro da: 04/30/21
166 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 68
Tutti i Tempi: 1,263
