Salta al contenuto principale
Gas Grill Ceramic Briquettes Replacement
Cosa ti serve
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: passo 1, immagine 1 di 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: passo 1, immagine 2 di 3 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: passo 1, immagine 3 di 3
    • Carefully lift grill plate located above briquettes
    • Make sure the gas grill is off and the propane is turned off before removing the grill plate
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: passo 2, immagine 1 di 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: passo 2, immagine 2 di 3 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: passo 2, immagine 3 di 3
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: passo 3, immagine 1 di 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: passo 3, immagine 2 di 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: passo 3, immagine 3 di 3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
    • A small container is recommended to keep the screws together
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: passo 4, immagine 1 di 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: passo 4, immagine 2 di 3 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: passo 4, immagine 3 di 3
    • Using your hands, gently unscrew washers from the back of the casing.
    • A small container is recommended to keep the washers together
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: passo 5, immagine 1 di 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: passo 5, immagine 2 di 3 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: passo 5, immagine 3 di 3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: passo 6, immagine 1 di 1
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: passo 7, immagine 1 di 1
    • Take 16 new ceramic briquettes out and carefully align them inside the casing.
    • Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
Conclusione
Altre 3 persone hanno completato questa guida.
emma
Membro da: 01/27/16
173 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 78
Tutti i Tempi: 3,587
