Salta al contenuto principale
GMMK-BRN Keyboard Switch Replacement
Cosa ti serve
  1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: passo 1, immagine 1 di 2 GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: passo 1, immagine 2 di 2
    • Unplug the keyboard from your device.
    • Place the keyboard on a clean workspace, along with the tools required.
  2. GMMK-BRN Keyboard Switch Replacement: passo 2, immagine 1 di 3 GMMK-BRN Keyboard Switch Replacement: passo 2, immagine 2 di 3 GMMK-BRN Keyboard Switch Replacement: passo 2, immagine 3 di 3
    • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
    • It is possible to damage the keycap if not pulled directly upwards.
  3. GMMK-BRN Keyboard Switch Replacement: passo 3, immagine 1 di 2 GMMK-BRN Keyboard Switch Replacement: passo 3, immagine 2 di 2
    • Use the switch remover to push the tabs in on the opposite sides of the switch.
    • Firmly pull the switch upwards.
    • If the switch is pulled at an angle, there is a risk to damaging the switch.
    • The switch may not come out easily, so more force may be required.
  4. GMMK-BRN Keyboard Switch Replacement: passo 4, immagine 1 di 3 GMMK-BRN Keyboard Switch Replacement: passo 4, immagine 2 di 3 GMMK-BRN Keyboard Switch Replacement: passo 4, immagine 3 di 3
    • Align the pins on the keycap with the ones inside the keyboard.
    • Insert the switch, and press down firmly until a click is heard.
  5. GMMK-BRN Keyboard Switch Replacement: passo 5, immagine 1 di 3 GMMK-BRN Keyboard Switch Replacement: passo 5, immagine 2 di 3 GMMK-BRN Keyboard Switch Replacement: passo 5, immagine 3 di 3
    • Align the cross of the keycap with the cross of the switch.
    • Push the keycap down firmly to reattach.
  6. GMMK-BRN Keyboard Switch Replacement: passo 6, immagine 1 di 2 GMMK-BRN Keyboard Switch Replacement: passo 6, immagine 2 di 2
    • Plug the keyboard back into your device.
    • Turn you device on and do a test to see if the new switch works.
Conclusione
Kyle Lieu Dang
Membro da: 01/30/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 315
