Salta al contenuto principale
Fused LED Light Replacement
Cosa ti serve
  1. Fused LED Light Replacement, Fused LED Light: passo 1, immagine 1 di 2 Fused LED Light Replacement, Fused LED Light: passo 1, immagine 2 di 2
    • Remove the upper semi-sphere diffuser by twisting or applying some heat with a heat gun or dryer to soften the adhesive.
  2. Fused LED Light Replacement: passo 2, immagine 1 di 3 Fused LED Light Replacement: passo 2, immagine 2 di 3 Fused LED Light Replacement: passo 2, immagine 3 di 3
    • Use a battery or a cell with connecting wires and apply them to the exposed solder ends on each LED.
    • The LED which doesn't lights up is detected as the faulty LED.
  3. Fused LED Light Replacement: passo 3, immagine 1 di 1
    • Using a knife or screwdriver, remove the faulty LED.
    • We need to replace it with a similar LED or a resistor.
    • Connecting the terminals directly can result in an increased current and multiple LED failure.
  4. Fused LED Light Replacement: passo 4, immagine 1 di 2 Fused LED Light Replacement: passo 4, immagine 2 di 2
    • Using the soldering iron solder an LED or a 100Ω (2W or 5W) resistor into the faulty LED space.
  5. Fused LED Light Replacement: passo 5, immagine 1 di 1
    • Connect the bulb to a power source to detect if it's working.
  6. Fused LED Light Replacement: passo 6, immagine 1 di 2 Fused LED Light Replacement: passo 6, immagine 2 di 2
    • Finally, twist the light-diffusing dome back on the light bulb.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 156
Tutti i Tempi: 6,520
