Salta al contenuto principale
Fujitsu Lifebook Stylistic Q584 Motherboard Replacement
Cosa ti serve
  1. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 3, immagine 1 di 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Inner Back Shield: passo 4, immagine 1 di 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 6, immagine 1 di 1
  7. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 7, immagine 1 di 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Battery: passo 8, immagine 1 di 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 10, immagine 1 di 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 11, immagine 1 di 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Motherboard: passo 12, immagine 1 di 1
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 14, immagine 1 di 1
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 15, immagine 1 di 1
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 16, immagine 1 di 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 16, immagine 2 di 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 16, immagine 3 di 3
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the connector with an ESD-safe spudger.
Conclusione
Altre 3 persone hanno completato questa guida.
Casey
Membro da: 03/25/19
280 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Henning Spring 2019 Membro di IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 Membri
3 Guide realizzate
Un commento
step16, that metal clip is supposed to be lifted up, not departed away
net ho - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,427
