Salta al contenuto principale
Fixing a scratchy pot/dial
  1. Fixing a scratchy pot/dial, Fixing the scratching noise: passo 1, immagine 1 di 1
    • To find what pot is making the noise by turning them to see what ones give a reaction
  2. Fixing a scratchy pot/dial, Cleaning the pot: passo 2, immagine 1 di 2 Fixing a scratchy pot/dial, Cleaning the pot: passo 2, immagine 2 di 2
    • Pour or spray some isopropyl alcohol into the pot and turn it to help clean the inside
    • Make sure to use as close to 100% purity isopropyl alcohol as you can for the best results!
    • If this doesn't work after a couple attempts you will most likely need to replace the volume pot.
Conclusione
Altre 2 persone hanno completato questa guida.
HelloMacOS
Membro da: 01/24/22
26.032 Reputazione
11 Guide realizzate
Repair is War on Entropy Membro di Repair is War on Entropy
Community
26 Membri
1.181 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 32
Tutti i Tempi: 552
