Salta al contenuto principale
Fender Jazz Bass Strings Replacement
Cosa ti serve
  1. Fender Jazz Bass Strings Replacement, Strings: passo 1, immagine 1 di 1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: passo 2, immagine 1 di 1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: passo 3, immagine 1 di 2 Fender Jazz Bass Strings Replacement: passo 3, immagine 2 di 2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: passo 4, immagine 1 di 2 Fender Jazz Bass Strings Replacement: passo 4, immagine 2 di 2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: passo 5, immagine 1 di 1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: passo 6, immagine 1 di 2 Fender Jazz Bass Strings Replacement: passo 6, immagine 2 di 2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 533
