Salta al contenuto principale
Dome Ceiling Light Bulb Replacement
Cosa ti serve
  1. Dome Ceiling Light Bulb Replacement, Light Bulb: passo 1, immagine 1 di 3 Dome Ceiling Light Bulb Replacement, Light Bulb: passo 1, immagine 2 di 3 Dome Ceiling Light Bulb Replacement, Light Bulb: passo 1, immagine 3 di 3
    • Before you start anything, make sure that the light switch has been turned off to avoid any electrical problems.
    • Gently turn the light in a counterclockwise direction with a gloved hand.
    • If the light is stuck, you can use the the grippier sole of a shoe to lightly nudge the light loose.
    • When the light starts moving enough, spin the light counterclockwise with the glove until it comes off.
  2. Dome Ceiling Light Bulb Replacement: passo 2, immagine 1 di 3 Dome Ceiling Light Bulb Replacement: passo 2, immagine 2 di 3 Dome Ceiling Light Bulb Replacement: passo 2, immagine 3 di 3
    • Put the lid on a soft safe surface.
    • Get the rag or cloth wet in order to wipe down the lid.
    • Clean the lid inside and out.
  3. Dome Ceiling Light Bulb Replacement: passo 3, immagine 1 di 3 Dome Ceiling Light Bulb Replacement: passo 3, immagine 2 di 3 Dome Ceiling Light Bulb Replacement: passo 3, immagine 3 di 3
    • Turn the light on without the cover to determine which bulb is blown out.
    • You can also check if the light looks black near the connection as a symbol it is going bad.
    • Turn off the power from the circuit breaker and turn off any light switches that provide power to the item you’re working on.
  4. Dome Ceiling Light Bulb Replacement: passo 5, immagine 1 di 2 Dome Ceiling Light Bulb Replacement: passo 5, immagine 2 di 2
    • Pull out the old burnt light, being sure not to drop it.
    • Plug the new replacement light into the plug in the light fixture.
    • In my case the bulb was a 120v 13w 4100k. This can very depending on model of light unit.
    • Watch how your light is supposed to match up with the plug when putting the new light in.
  5. Dome Ceiling Light Bulb Replacement: passo 6, immagine 1 di 1
    • Turn on the light and make sure both lights turn on. If it doesn't turn on try pushing in the light more—it's a common error when installing.
  6. Dome Ceiling Light Bulb Replacement: passo 7, immagine 1 di 2 Dome Ceiling Light Bulb Replacement: passo 7, immagine 2 di 2
    • Spin the lid clockwise with your gloved hand until you can't turn it anymore.
    • Hit the lid clockwise with the heel of the shoe to tighten up the lid and avoid any accidents and loose ends.
  7. Dome Ceiling Light Bulb Replacement: passo 8, immagine 1 di 2 Dome Ceiling Light Bulb Replacement: passo 8, immagine 2 di 2
    • Using the wet rag or cloth, again clean up the light to remove any shoe marks you might have caused in the process.
    • Turn on light and watch your hard work glow!
Conclusione
Jalen Brown
Membro da: 01/26/21
145 Reputazione
1 Guida realizzata
2 Commenti
Thank you so much for your great instructions! I had tried twisting both clockwise and counter clockwise to get to the bulbs, but was afraid of breaking it because it is twisted on so tight. Now that I found your instructions, I will apply a bit more elbow grease.
Thanks again!
Gruneichtime - Replica
Hi any idea where I can get a replacement glass dome for these types of light?
Ray Ray - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 79
Ultimi 30 Giorni: 349
Tutti i Tempi: 10,659
