Salta al contenuto principale
Disassembling Power Mac G4 M5183 DVD-ROM Drive
Cosa ti serve
  1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: passo 1, immagine 1 di 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: passo 1, immagine 2 di 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 2, immagine 1 di 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 2, immagine 2 di 2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 3, immagine 1 di 1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 4, immagine 1 di 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 4, immagine 2 di 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: passo 4, immagine 3 di 3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  5. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 5, immagine 1 di 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 5, immagine 2 di 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: passo 5, immagine 3 di 3
    • Remove DVD drive from the drive bay.
    • Lift the two metal tabs on the back of the shielding and remove.
    • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
    • Slide out DVD drive.
Conclusione
Altre 11 persone hanno completato questa guida.
Cal Poly, Team 13-24, Maness Winter 2010 Membro di Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 11,191
