Salta al contenuto principale
Disassembling Macintosh IIsi Floppy Drive
Cosa ti serve
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: passo 1, immagine 1 di 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: passo 1, immagine 2 di 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: passo 2, immagine 1 di 3 Disassembling Macintosh IIsi Floppy Drive: passo 2, immagine 2 di 3 Disassembling Macintosh IIsi Floppy Drive: passo 2, immagine 3 di 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: passo 3, immagine 1 di 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: passo 3, immagine 2 di 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: passo 3, immagine 3 di 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: passo 4, immagine 1 di 3 Disassembling Macintosh IIsi Floppy Drive: passo 4, immagine 2 di 3 Disassembling Macintosh IIsi Floppy Drive: passo 4, immagine 3 di 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
Conclusione
Altre 2 persone hanno completato questa guida.
Chris Green
Membro da: 10/11/09
37.146 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.512 Guide realizzate
Un commento
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,784
