Salta al contenuto principale
Craig CMP801 Volume Controls Replacement
Cosa ti serve
  1. Craig CMP801 Volume Controls Replacement, Back Cover: passo 1, immagine 1 di 2 Craig CMP801 Volume Controls Replacement, Back Cover: passo 1, immagine 2 di 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Volume Controls Replacement: passo 2, immagine 1 di 2 Craig CMP801 Volume Controls Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Volume Controls Replacement: passo 3, immagine 1 di 2 Craig CMP801 Volume Controls Replacement: passo 3, immagine 2 di 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Volume Controls Replacement, Volume Controls: passo 4, immagine 1 di 2 Craig CMP801 Volume Controls Replacement, Volume Controls: passo 4, immagine 2 di 2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 Volume Controls Replacement: passo 5, immagine 1 di 2 Craig CMP801 Volume Controls Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    Compra
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 Volume Controls Replacement: passo 6, immagine 1 di 2 Craig CMP801 Volume Controls Replacement: passo 6, immagine 2 di 2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 272
