Salta al contenuto principale
Come sostituire il sensore del tasto Home.
Cosa ti serve
    • In questa guida imparerai come riparare il tasto Home dell'iPhone 7. Per vedere altre riparazioni degli iPhone, dai un 'occhiata alle alle altre mie guide!
Conclusione
Per rimontare il dispositivo segui le istruzioni in ordine inverso.
Altre 18 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Alex Sander
Membro da: 02/28/17
38.237 Reputazione
202 Guide realizzate
11 Commenti
Do you have clear instructions and tools how to do it
Abbigail huari - Replica
So do you need to move the chip to replace the home button?
Dylan McGarrity - Replica
You need to reball or replace the chip to repair Touch ID.
Alex Sander -
If the home button or its flex cable is broken then it's completely shot, short of taking it to an Apple store for a replacement.
On the other hand, it could also be caused by the home button's extension flex cable running through the back of the lcd, and/or a damaged camera/speaker flex cable on top. So make sure to check all those out carefully before resorting to the Apple store.
After reading through a lot of suggestions, here's one which sounded interesting to me. Low and behold, this solution has actually worked!! I have removed that single screw completely, restarted the phone, and the home button started working perfectly.
05/31/2017 by screensaviors
I loosened the screw behind the center of the home button (holding it to the metal bracket), and it magically works now. This may not fix a lot of them, but it worked for me. I was just tightening that screw snug, but must have been too snug.
billa.4you - Replica
Very good points, it will certainly help people to resolve some of their problems, thanks for sharing your experience!
Alex Sander -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 118
Tutti i Tempi: 35,787
