Salta al contenuto principale
Coin Display Case Glass Attachment
Cosa ti serve
  1. Coin Display Case Glass Attachment, Coin Display Case Glass Attachment: passo 1, immagine 1 di 2 Coin Display Case Glass Attachment, Coin Display Case Glass Attachment: passo 1, immagine 2 di 2
    • Clean the display case thoroughly with glass cleaner and a paper towel.
  2. Coin Display Case Glass Attachment: passo 2, immagine 1 di 1
    • Gently pry the glass away from the glue on the frame. Be careful not to shatter the glass.
  3. Coin Display Case Glass Attachment: passo 3, immagine 1 di 1
    • Apply a thin, solid line of a strong adhesive, such as Gorilla Glue, to the entire inner border of the display case where the glass attaches.
  4. Coin Display Case Glass Attachment: passo 4, immagine 1 di 2 Coin Display Case Glass Attachment: passo 4, immagine 2 di 2
    • Gently, but firmly, press the glass back into the felt lining. Run your finger with firm pressure along the entire lining of the glass two times.
  5. Coin Display Case Glass Attachment: passo 5, immagine 1 di 1
    • Allow the glue to set for 2-4 hours for the strongest bond.
    • Keep the case in the upright position while the glue sets.
    • Do not close or shut the case during the drying/setting process.
Conclusione
Allow the glass and glue to bond for at least 6 hours before using the case.
Jesse Norris
Membro da: 02/08/16
113 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,044
