Salta al contenuto principale
Citizen Men's Watch 1102 Series Hands Replacement
Cosa ti serve
  1. Citizen Men's Watch 1102 Series Hands Replacement, Watch Face Hands: passo 1, immagine 1 di 1
    • Locate the notch under the back cap of the watch. Wedge the jimmy into the notch, and pry off the back.
  2. Citizen Men's Watch 1102 Series Hands Replacement: passo 2, immagine 1 di 1
    • Remove the circular plastic cover from inside the watch.
  3. Citizen Men's Watch 1102 Series Hands Replacement: passo 3, immagine 1 di 1
    • Remove the crown stalk by placing the needle in the release notch. This will release stalk and allow it to slide out.
  4. Citizen Men's Watch 1102 Series Hands Replacement: passo 4, immagine 1 di 1
    • Turn watch on its side and let the watch face fall out.
  5. Citizen Men's Watch 1102 Series Hands Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently pry the watch hands off of the face of the watch with the jimmy and tweezers.
  6. Citizen Men's Watch 1102 Series Hands Replacement: passo 6, immagine 1 di 1
    • Use the tweezers to replace the hands of the watch.
    • First, place the hour hand on the watch face stem, followed by the minute hand, and the second hand.
  7. Citizen Men's Watch 1102 Series Hands Replacement: passo 7, immagine 1 di 1
    • Place the watch face downwards in its case.
    • Make sure the crown stalk holes are aligned.
  8. Citizen Men's Watch 1102 Series Hands Replacement: passo 8, immagine 1 di 1
    • Insert the crown stalk into the crown stalk holes.
  9. Citizen Men's Watch 1102 Series Hands Replacement: passo 9, immagine 1 di 1
    • Place the plastic cover back in its original place.
    • Use the crown notch for guidance in alignment.
  10. Citizen Men's Watch 1102 Series Hands Replacement: passo 10, immagine 1 di 1
    • Press the back cover on the watch using hands or clamp, until it pops into place.
Conclusione
Now that the watch hands are repaired, the watch can be reset manually so that the it can keep the correct time.
Justin Sidwell
Membro da: 02/28/17
111 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,572
