Salta al contenuto principale
Char-Broil Grill Burner Replacement
Cosa ti serve
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: passo 1, immagine 1 di 1
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: passo 2, immagine 1 di 2 Char-Broil Grill Burner Replacement: passo 2, immagine 2 di 2
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: passo 3, immagine 1 di 1
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: passo 4, immagine 1 di 2 Char-Broil Grill Burner Replacement: passo 4, immagine 2 di 2
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: passo 5, immagine 1 di 1
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: passo 6, immagine 1 di 3 Char-Broil Grill Burner Replacement: passo 6, immagine 2 di 3 Char-Broil Grill Burner Replacement: passo 6, immagine 3 di 3
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
Conclusione
Altre 2 persone hanno completato questa guida.
Dan
Membro da: 10/01/17
155 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 88
Tutti i Tempi: 667
