Salta al contenuto principale
Car and Truck Wiper Blades Replacement
Cosa ti serve
  1. Car and Truck Wiper Blades Replacement, Wiper Blades: passo 1, immagine 1 di 1
    • Lift your wiper blades off the windshield.
  2. Car and Truck Wiper Blades Replacement: passo 2, immagine 1 di 1
    • Cover the windshield with a towel or blanket to avoid shattering the windshield if the wiper arms come down accidentally after the blades are removed.
  3. Car and Truck Wiper Blades Replacement: passo 3, immagine 1 di 1
    • The wiper blades are typically connected to the wiper arm with a hook type of closure. Lift the plastic cover and slide the wiper backward to disconnect and carefully remove it. Repeat for the other side.
    • Unpackage your replacement wiper blades, and carefully lift the plastic cover covering the hook connector.
  4. Car and Truck Wiper Blades Replacement: passo 5, immagine 1 di 1
    • Slide the hook from the wiper arm into the wiper blade and tug slightly until securely connected. Replace the cover and repeat on the other side.
  5. Car and Truck Wiper Blades Replacement: passo 6, immagine 1 di 1
    • Remove the towel from the windshield and lower the wiper arms back onto the windshield.
    • Test the wiper blades to ensure they're securely connected and working properly.
Conclusione
When in doubt, consult your owner's manual or the back of the wiper blade package for further instructions.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 52
Tutti i Tempi: 313
