Salta al contenuto principale
Car and Truck Battery Replacement
Cosa ti serve
  1. Car and Truck Battery Replacement, How to Disconnect a Car or Truck Battery: passo 1, immagine 1 di 3 Car and Truck Battery Replacement, How to Disconnect a Car or Truck Battery: passo 1, immagine 2 di 3 Car and Truck Battery Replacement, How to Disconnect a Car or Truck Battery: passo 1, immagine 3 di 3
    • Before you begin, switch the ignition off and remove the key.
    • Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
    • Put on work gloves and safety goggles if you have them available.
    • In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
    • Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
  2. Car and Truck Battery Replacement, Open the hood (bonnet): passo 2, immagine 1 di 3 Car and Truck Battery Replacement, Open the hood (bonnet): passo 2, immagine 2 di 3 Car and Truck Battery Replacement, Open the hood (bonnet): passo 2, immagine 3 di 3
    • Most motor vehicle batteries are located in the engine bay, under the hood (a.k.a. bonnet). If your battery is located elsewhere, skip to Step 5.
    • If you're not sure, simply continue reading.
    • Pull the hood release lever. It's usually located inside the car, near the steering wheel.
  3. Car and Truck Battery Replacement: passo 3, immagine 1 di 3 Car and Truck Battery Replacement: passo 3, immagine 2 di 3 Car and Truck Battery Replacement: passo 3, immagine 3 di 3
    • Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
  4. Car and Truck Battery Replacement: passo 4, immagine 1 di 3 Car and Truck Battery Replacement: passo 4, immagine 2 di 3 Car and Truck Battery Replacement: passo 4, immagine 3 di 3
    • At this point, depending on the vehicle, your hood may raise and support itself automatically.
    • If not, use one hand to hold the hood open temporarily while securing the hood with the prop rod:
    • Lift one end of the prop rod up or out to release it from the front area of the engine bay.
    • Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
    • Make sure the hood is well secured before you let go with your other hand, or it may fall and injure you.
  5. Car and Truck Battery Replacement: passo 5, immagine 1 di 3 Car and Truck Battery Replacement: passo 5, immagine 2 di 3 Car and Truck Battery Replacement: passo 5, immagine 3 di 3
    • Locate the battery. It's normally rectangular and roughly 8-14" across.
    • The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols.
    • On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
  6. Car and Truck Battery Replacement: passo 6, immagine 1 di 3 Car and Truck Battery Replacement: passo 6, immagine 2 di 3 Car and Truck Battery Replacement: passo 6, immagine 3 di 3
    • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
    • Always disconnect the negative cable first (before removing the positive cable).
    • The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
    • If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
  7. Car and Truck Battery Replacement: passo 7, immagine 1 di 2 Car and Truck Battery Replacement: passo 7, immagine 2 di 2
    • Remove the cable from the negative battery terminal.
    • When connecting the battery, it is advised to roughen up the battery terminals and clean the cable clamp beforehand.
    • Upon reconnecting the battery, make sure to seal the pole connections with an appropriate terminal grease or terminal spray.
  8. Car and Truck Battery Replacement: passo 8, immagine 1 di 2 Car and Truck Battery Replacement: passo 8, immagine 2 di 2
    • Prevent the cable from making accidental contact with the terminal by pushing it aside and/or wrapping the cable clamp with a dry rag.
  9. Car and Truck Battery Replacement, Battery: passo 9, immagine 1 di 2 Car and Truck Battery Replacement, Battery: passo 9, immagine 2 di 2
    • Remove the insulating cover from the positive battery terminal (if one is present).
  10. Car and Truck Battery Replacement: passo 10, immagine 1 di 2 Car and Truck Battery Replacement: passo 10, immagine 2 di 2
    • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the positive battery terminal.
  11. Car and Truck Battery Replacement: passo 11, immagine 1 di 2 Car and Truck Battery Replacement: passo 11, immagine 2 di 2
    • Remove the cable from the positive battery terminal.
    • During reassembly, be sure to reconnect and tighten the positive cable clamp first (before the negative cable clamp).
  12. Car and Truck Battery Replacement: passo 12, immagine 1 di 1
    • Remove any bolts securing the battery.
  13. Car and Truck Battery Replacement: passo 13, immagine 1 di 1
    • Remove any bars or brackets securing the battery.
  14. Car and Truck Battery Replacement: passo 14, immagine 1 di 2 Car and Truck Battery Replacement: passo 14, immagine 2 di 2
    • Remove the battery.
    • A typical car battery can weigh 50 pounds or more, so lift carefully and get help if needed. Do not drop the battery, as this can release dangerous chemicals.
    • If your battery cable clamps look dirty and/or corroded, clean them up with a wire brush and a mixture of water and baking soda before installing your new battery.
    • To prevent corrosion in the future, coat the new battery's terminals with a little dielectric grease or petroleum jelly.
    • Don't throw the old battery in the trash. Many auto parts stores and service stations will accept old batteries for free safe disposal.
Conclusione
Altre 21 persone hanno completato questa guida.
Jeff Suovanen
Membro da: 08/06/13
429.556 Reputazione
259 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.524 Guide realizzate
3 Commenti
You should not just tell people to follow the directions in reverse order for reassembly. There are some steps most mechanics will want you to perform (e.g. applying a compound to the terminals to prevent corrosion) in addition to simply reattaching the cables.
shamino - Replica
As with most guides on iFixit, reassembly tips are included on the applicable step where appropriate.
Jeff Suovanen -
good for car batery replacement
CanadaVisitorVisa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 66
Ultimi 30 Giorni: 254
Tutti i Tempi: 11,980
