Salta al contenuto principale
Boss RC-1 Loop Station-Pedal Battery Replacement
Cosa ti serve
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 2, immagine 1 di 1
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 3, immagine 1 di 2 Boss RC-1 Loop Station-Pedal Battery Replacement: passo 3, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 4, immagine 1 di 1
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: passo 6, immagine 1 di 1
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
Conclusione
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 101
Tutti i Tempi: 5,392
