Salta al contenuto principale
Bosch GST90BE Jigsaw Speed Control Board Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-6 provengono da una guida contrassegnata come in corso.
    Bosch GST90BE Jigsaw Speed Control Board Replacement, Diagnosis: passo 1, immagine 1 di 1
    • This is the Bosch gst90be, a hand held Jigsaw from the Bosch Pro range.
    • This guide will show you how to disassemble it to make repairs.
  2. Bosch GST90BE Jigsaw Speed Control Board Replacement, Removing base shoe: passo 2, immagine 1 di 2 Bosch GST90BE Jigsaw Speed Control Board Replacement, Removing base shoe: passo 2, immagine 2 di 2
    • Undo and remove 5mm Hex screw and square washer from Shoe, and remove shoe.
  3. Bosch GST90BE Jigsaw Speed Control Board Replacement, Remove blade lever: passo 3, immagine 1 di 2 Bosch GST90BE Jigsaw Speed Control Board Replacement, Remove blade lever: passo 3, immagine 2 di 2
    • Remove 1 T20 Torx screw and washer from blade lever, then remove blade lever and spring.
  4. Bosch GST90BE Jigsaw Speed Control Board Replacement, Remove metal cover and wire blade guard: passo 4, immagine 1 di 3 Bosch GST90BE Jigsaw Speed Control Board Replacement, Remove metal cover and wire blade guard: passo 4, immagine 2 di 3 Bosch GST90BE Jigsaw Speed Control Board Replacement, Remove metal cover and wire blade guard: passo 4, immagine 3 di 3
    • Remove 2 Posidriv screws from front cover, then slide off front cover and remove wire blade guard, which rests in a recess behind the metal cover.
    • Remove one Torx T20 screw
  5. Bosch GST90BE Jigsaw Speed Control Board Replacement, Disassembly: passo 5, immagine 1 di 1
    • Remove eight T20 Torx screws from the body of the saw. (The ninth screw was under the silver metal cover).
  6. Bosch GST90BE Jigsaw Speed Control Board Replacement, Separate casing: passo 6, immagine 1 di 1
    • You can now separate the two halves of the saw, which allows you to access all of the components
    • To reassemble the saw, follow the instructions in this guide in reverse order.
  7. Bosch GST90BE Jigsaw Speed Control Board Replacement, Diagnosis.: passo 7, immagine 1 di 1
    • There are 4 main types of electrical problem with a Power tool, Cable, Motor, Switch or Speed control.
    • The cable and switch can be easily checked out with a meter, as can the motor.
    • If all of these seem OK, then the speed control PCB may have failed. When the board fails, the drill just does not work at all.
    • Before replacing the board, it is worth blowing some compressed air through the speed Knob, as these can get full of dust and that will stop the saw working.
  8. Bosch GST90BE Jigsaw Speed Control Board Replacement, Removing the speed control board: passo 8, immagine 1 di 3 Bosch GST90BE Jigsaw Speed Control Board Replacement, Removing the speed control board: passo 8, immagine 2 di 3 Bosch GST90BE Jigsaw Speed Control Board Replacement, Removing the speed control board: passo 8, immagine 3 di 3
    • If you have disassembled the saw using the previous instructions, you can now access all of the components.
    • The Control board is at the rear. as shown in the main image. It can slide out now that the case is separated.
    • It is connected to the motor by two wires with copper push-in connectors, a blue one at the front and a white one at the other side, which is under the motor
    • There are two longer wires leading to push-in connectors on the switch, a black one and a white one. There is also a multi-pin connector for the speed control cable.
  9. Bosch GST90BE Jigsaw Speed Control Board Replacement, Optional Bypassing the speed control board: passo 9, immagine 1 di 3 Bosch GST90BE Jigsaw Speed Control Board Replacement, Optional Bypassing the speed control board: passo 9, immagine 2 di 3 Bosch GST90BE Jigsaw Speed Control Board Replacement, Optional Bypassing the speed control board: passo 9, immagine 3 di 3
    • If , like me, you never use the speed control on the Jigsaw, you can remove it permanently, and bypass it.
    • To do so, you will need to cut the wires between the switch and the PCB, and the PCB and the motor.
    • Then join the white wires together, and the black and blue wires together. The multi-pin connector is for the variable speed trigger and is not required.
    • I did this by soldering them together and covering the joints in Heat-shrink tubing.
    • It is recommended to add an X2 0.1μF 310V capacitor between the white and black wires to prevent electrical noise and excessive sparking from the motor brushes, which would shorten the life of the motor, I did this by soldering one leg of the capacitor to the joint between the white cables and one to the joint between the blue and black wires.
    • Take care that the wires are routed correctly through the notches in the case frame, so they will not be compressed when you reassemble the saw
  10. Bosch GST90BE Jigsaw Speed Control Board Replacement: passo 10, immagine 1 di 1
    • Both joints and the capacitor legs should be covered in heat-shrink tubing to insulate them
  11. Bosch GST90BE Jigsaw Speed Control Board Replacement, Spark suppression capacitor: passo 11, immagine 1 di 1
    • This is the type of capacitor I used, available very cheaply on Ebay
Conclusione
To reassemble your device, follow the instructions from the first guide in reverse order.
Leo Maxwell
Membro da: 01/25/20
855 Reputazione
4 Guide realizzate
2 Commenti
Bravo Mr. Maxwell. More of your lessons will be appreciated
Ejike Sebastine C. - Replica
The same values would be fine.
The 310V value is just a maximum tolerance, that capacitor would be fine for 110v.
Leo Maxwell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 51
Tutti i Tempi: 1,609
