Salta al contenuto principale
Bed boards Replacement
Cosa ti serve
  1. Bed boards Replacement, Bed Boards: passo 1, immagine 1 di 2 Bed boards Replacement, Bed Boards: passo 1, immagine 2 di 2
    • Remove the matress from the bed.
  2. Bed boards Replacement: passo 2, immagine 1 di 1
    • Remove the box spring from the bed.
  3. Bed boards Replacement: passo 3, immagine 1 di 1
    • Remove the old boards using the Phillips #1 screwdriver.
  4. Bed boards Replacement: passo 4, immagine 1 di 1
    • Using your measure tape, measure the old boards and write down the measurements.
  5. Bed boards Replacement: passo 5, immagine 1 di 1
    • Find some wooden boards with 2x2 measures (width) and with the length you already measured.
  6. Bed boards Replacement: passo 6, immagine 1 di 2 Bed boards Replacement: passo 6, immagine 2 di 2
    • Screw in the replacement boards.
  7. Bed boards Replacement: passo 7, immagine 1 di 3 Bed boards Replacement: passo 7, immagine 2 di 3 Bed boards Replacement: passo 7, immagine 3 di 3
    • Put your box spring and mattress back and you are done.
Conclusione
To assemble your bed boards just follow the steps provided in the order given and your bed boards will be ready to go.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 53
Tutti i Tempi: 935
