Salta al contenuto principale
BMW F10 M5 LED Reverse Light Installation
Cosa ti serve
  1. BMW F10 M5 LED Reverse Light Installation, BMW F10 M5 Reverse Lights: passo 1, immagine 1 di 1
    • Gain access to the back of the trunk
    • Remove some clips that hold the trunk liner in place.
    • Tip: You don't have to remove all the clips, just enough so you have enough access.
  2. BMW F10 M5 LED Reverse Light Installation: passo 2, immagine 1 di 1
    • Pull out the bulb tray.
    • Press the two clips on the side to release.
  3. BMW F10 M5 LED Reverse Light Installation: passo 3, immagine 1 di 2 BMW F10 M5 LED Reverse Light Installation: passo 3, immagine 2 di 2
    • Remove the bulb and swap it out with the new LED bulb.
  4. BMW F10 M5 LED Reverse Light Installation: passo 4, immagine 1 di 2 BMW F10 M5 LED Reverse Light Installation: passo 4, immagine 2 di 2
    • Test to see if the LED reverse lights work and enjoy.
Conclusione
Installation will take absolutely no time at all and you will be on your way to some new LED reverse lights.
Altre 3 persone hanno completato questa guida.
Eric Wu
Membro da: 01/21/15
3.357 Reputazione
23 Guide realizzate
Un commento
Any idea how to do this on the Station Wagon/ Tourer model F11d
The liner does not have easily removable clips. The tool box cover reveals several screws and 2 recessed expanding plastic catches which I cant get out . Removed all the screws has not impact.
Thanks
david meredith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 55
Tutti i Tempi: 9,846
