Salta al contenuto principale
Apple iPod Hi-Fi Grille Replacement
Cosa ti serve
  1. Apple iPod Hi-Fi Grille Replacement, Grille: passo 1, immagine 1 di 1
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: passo 2, immagine 1 di 1
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: passo 3, immagine 1 di 1
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team S16-G1, Livingston Spring 2018 Membro di Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,458
