Salta al contenuto principale
Apple Thunderbolt Display Webcam and Mic Replacement
Cosa ti serve
  1. Apple Thunderbolt Display Webcam and Mic Replacement, LCD: passo 1, immagine 1 di 3 Apple Thunderbolt Display Webcam and Mic Replacement, LCD: passo 1, immagine 2 di 3 Apple Thunderbolt Display Webcam and Mic Replacement, LCD: passo 1, immagine 3 di 3
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
  2. Apple Thunderbolt Display Webcam and Mic Replacement: passo 2, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 2, immagine 2 di 2
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
  3. Apple Thunderbolt Display Webcam and Mic Replacement: passo 3, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 3, immagine 2 di 2
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
  4. Apple Thunderbolt Display Webcam and Mic Replacement: passo 4, immagine 1 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 4, immagine 2 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 4, immagine 3 di 3
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
  5. Apple Thunderbolt Display Webcam and Mic Replacement: passo 5, immagine 1 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 5, immagine 2 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 5, immagine 3 di 3
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
  6. Apple Thunderbolt Display Webcam and Mic Replacement: passo 6, immagine 1 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 6, immagine 2 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 6, immagine 3 di 3
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
  7. Apple Thunderbolt Display Webcam and Mic Replacement: passo 7, immagine 1 di 1
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
  8. Apple Thunderbolt Display Webcam and Mic Replacement: passo 8, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 8, immagine 2 di 2
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
  9. Apple Thunderbolt Display Webcam and Mic Replacement, Webcam and Mic: passo 9, immagine 1 di 3 Apple Thunderbolt Display Webcam and Mic Replacement, Webcam and Mic: passo 9, immagine 2 di 3 Apple Thunderbolt Display Webcam and Mic Replacement, Webcam and Mic: passo 9, immagine 3 di 3
    • The webcam and microphone are located at the top of the device. First, follow the white microphone wire down to its connector in the logic board.
    • Carefully pull the white wire's connector from the logic board.
  10. Apple Thunderbolt Display Webcam and Mic Replacement: passo 10, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 10, immagine 2 di 2
    • Follow the wire down from the webcam and find where it is connected into the logic board.
    • Carefully remove the connector from the logic board.
  11. Apple Thunderbolt Display Webcam and Mic Replacement: passo 11, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • The wires are held in place by three pieces of tape. Remove the tape out of the way so that the wires are free.
    • It is very easy to remove the pieces of tape using tweezers. They aren't completely necessary though.
  12. Apple Thunderbolt Display Webcam and Mic Replacement: passo 12, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 12, immagine 2 di 2
    • Back at the top of the device, there are two pieces of silver tape holding the webcam wires in place.
    • Again, tweezers are helpful but aren't necessary for removal of the silver tape.
    • Next, remove the tape that is holding the microphone in place.
  13. Apple Thunderbolt Display Webcam and Mic Replacement: passo 13, immagine 1 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 13, immagine 2 di 3 Apple Thunderbolt Display Webcam and Mic Replacement: passo 13, immagine 3 di 3
    • The webcam is held in with two screws and a connector
    • Unscrew the two screws holding the webcam in place with the TR 10 screwdriver.
    • The webcam is now free from your display!
  14. Apple Thunderbolt Display Webcam and Mic Replacement: passo 14, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 14, immagine 2 di 2
    • With the webcam removed, the microphone is now visible.
    • The webcam is held in place with a plastic clip that has foam adhesive stuck to the casing.
    • Use a plastic spudger to pry underneath the clip and separate the clip from the casing.
  15. Apple Thunderbolt Display Webcam and Mic Replacement: passo 15, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 15, immagine 2 di 2
    • The actual microphone itself is stuck to the top of the casing using a small amount of adhesive and covered by a piece of tape.
    • Remove the piece of tape using either tweezers or your fingers to have access to the microphone.
    • Use the plastic spudger again to get underneath the small round microphone and pry it loose from the adhesive.
  16. Apple Thunderbolt Display Webcam and Mic Replacement: passo 16, immagine 1 di 2 Apple Thunderbolt Display Webcam and Mic Replacement: passo 16, immagine 2 di 2
    • The wires for both the webcam and the microphone are tucked underneath a few other components.
    • Carefully pull the wires out up and out from the other components and your webcam and microphone can be replaced.
Conclusione
Altre 4 persone hanno completato questa guida.
Wesley Ho
Membro da: 04/14/15
455 Reputazione
1 Guida realizzata
Cal Poly, Team 5-11, Maness Spring 2015 Membro di Cal Poly, Team 5-11, Maness Spring 2015
CPSU-MANESS-S15S5G11
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,786
