Salta al contenuto principale
Apple Studio Display M7649 Rear Panel Replacement
Cosa ti serve
  1. Apple Studio Display M7649 Rear Panel Replacement, Stand: passo 1, immagine 1 di 2 Apple Studio Display M7649 Rear Panel Replacement, Stand: passo 1, immagine 2 di 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Rear Panel Replacement, Panels: passo 2, immagine 1 di 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Rear Panel Replacement: passo 3, immagine 1 di 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Rear Panel Replacement: passo 4, immagine 1 di 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Alan Truong
Membro da: 01/19/10
566 Reputazione
3 Guide realizzate
Cal Poly, Team 3-20, Maness Winter 2010 Membro di Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,710
