Salta al contenuto principale
Apple Studio Display M2454 CCFL Inverter Replacement
Cosa ti serve
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: passo 1, immagine 1 di 2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: passo 1, immagine 2 di 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: passo 2, immagine 1 di 1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: passo 3, immagine 1 di 2 Apple Studio Display M2454 CCFL Inverter Replacement: passo 3, immagine 2 di 2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: passo 4, immagine 1 di 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: passo 5, immagine 1 di 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: passo 6, immagine 1 di 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
Linea Traguardo
Dylan Perry
Membro da: 01/20/10
177 Reputazione
5 Guide realizzate
Cal Poly, Team 13-27, Maness Winter 2010 Membro di Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 6,744
