Salta al contenuto principale
Apple Powerbook 520 Floppy Drive Replacement
Cosa ti serve
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: passo 1, immagine 1 di 1
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: passo 2, immagine 1 di 1
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: passo 3, immagine 1 di 1
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: passo 4, immagine 1 di 1
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: passo 5, immagine 1 di 1
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: passo 6, immagine 1 di 1
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: passo 7, immagine 1 di 1
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: passo 8, immagine 1 di 1
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Kevin Peters
Membro da: 04/19/11
130 Reputazione
1 Guida realizzata
Cal Poly, Team 20-66, Walters Spring 2011 Membro di Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Membri
3 Guide realizzate
Un commento
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,748
