Salta al contenuto principale
Apple PowerBook G3 400 Keyboard Replacement
  1. Apple PowerBook G3 400 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 Keyboard Replacement: passo 2, immagine 1 di 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 Keyboard Replacement: passo 3, immagine 1 di 1
    • Your computer should look approximately like this.
Conclusione
Byron Hoefer
Membro da: 04/18/11
70 Reputazione
2 Guide realizzate
Cal Poly, Team 4-2, Regan Spring 2011 Membro di Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,778
