Salta al contenuto principale
Apple Lisa XLerator 12.5/18 Installation
Cosa ti serve
  1. Apple Lisa XLerator 12.5/18 Installation, Disassembly: passo 1, immagine 1 di 2 Apple Lisa XLerator 12.5/18 Installation, Disassembly: passo 1, immagine 2 di 2
  2. Apple Lisa XLerator 12.5/18 Installation, Remove the CPU Board: passo 2, immagine 1 di 2 Apple Lisa XLerator 12.5/18 Installation, Remove the CPU Board: passo 2, immagine 2 di 2
    • Remove the CPU Board. It is marked in blue.
    • Lift up on the CPU Board's clips.
    • Lift up the CPU Board to remove.
  3. Apple Lisa XLerator 12.5/18 Installation, Remove CPU Chip: passo 3, immagine 1 di 1
    • Locate the CPU at location 13A/B/C (the big one.)
    • Remove the CPU. I used a flat head screwdriver to gently pry up the chip although there are better tools such as a Chip Remover.
  4. Apple Lisa XLerator 12.5/18 Installation, Insert the XLerator: passo 4, immagine 1 di 1
    • Insert the XLerator in the CPU's socket.
    • Ensure it "click" in all the way.
    • If the XLerator seems loose then use electrical tape at your discretion to secure it to the CPU Board.
  5. Apple Lisa XLerator 12.5/18 Installation, Reassembly: passo 5, immagine 1 di 2 Apple Lisa XLerator 12.5/18 Installation, Reassembly: passo 5, immagine 2 di 2
    • Reinstall the CPU Board into the Lisa's Card Cage.
    • Reinstall the Lisa's Card Cage into the Lisa.
    • Reinstall the Lisa's rear panel.
  6. Apple Lisa XLerator 12.5/18 Installation, Installing the Software: passo 6, immagine 1 di 3 Apple Lisa XLerator 12.5/18 Installation, Installing the Software: passo 6, immagine 2 di 3 Apple Lisa XLerator 12.5/18 Installation, Installing the Software: passo 6, immagine 3 di 3
Conclusione
LisaGuide
Membro da: 12/30/18
1.833 Reputazione
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 528
