Salta al contenuto principale
Apple Lisa SCSI Card Installation
Cosa ti serve
  1. Apple Lisa SCSI Card Installation, Disassembly: passo 1, immagine 1 di 2 Apple Lisa SCSI Card Installation, Disassembly: passo 1, immagine 2 di 2
  2. Apple Lisa SCSI Card Installation, Installing the SCSI Card: passo 2, immagine 1 di 2 Apple Lisa SCSI Card Installation, Installing the SCSI Card: passo 2, immagine 2 di 2
    • Locate Lisa's expansion slots.
    • Locate expansion slot 3.
    • Pull the metal rod out from slot 3 and rotate 90º clockwise.
    • Slide the SCSI Card into expansion slot 3.
    • Rotate the metal rod, as described before, 90º counter-clockwise and push in to secure the Lisa DAC.
    • The SCSI card includes 1 internal connector and 1 external connector.
    • The internal connector is used for connecting a hard disk.
    • If you intend to connect a hard disk then connect it now.
    • Pin 1 is marked.
    • The SCSI Card can also be cut to accommodate a Card Cage fan upon order request.
  3. Apple Lisa SCSI Card Installation, Reinstall Rear Panel: passo 4, immagine 1 di 1
    • Reinstall the Lisa's rear panel.
  4. Apple Lisa SCSI Card Installation, Using the SCSI Card: passo 5, immagine 1 di 1
    • The SCSI Card requires MacWorks Plus II.
    • To use devices connected to the SCSI card please refer to the device's manual for proper device installation.
    • This SCSI card was installed to use an Apple External SCSI CD-ROM Drive.
Conclusione
LisaGuide
Membro da: 12/30/18
1.833 Reputazione
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 526
