Salta al contenuto principale
Apple Cinema Display M8149 USB Port Replacement
Cosa ti serve
  1. Apple Cinema Display M8149 USB Port Replacement, USB Port: passo 1, immagine 1 di 3 Apple Cinema Display M8149 USB Port Replacement, USB Port: passo 1, immagine 2 di 3 Apple Cinema Display M8149 USB Port Replacement, USB Port: passo 1, immagine 3 di 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Apple Cinema Display M8149 USB Port Replacement: passo 2, immagine 1 di 3 Apple Cinema Display M8149 USB Port Replacement: passo 2, immagine 2 di 3 Apple Cinema Display M8149 USB Port Replacement: passo 2, immagine 3 di 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Once the screws are removed, lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Apple Cinema Display M8149 USB Port Replacement: passo 3, immagine 1 di 1
    • Unscrew the USB cable routing screw (8 x 2.72mm) using the PH 2 screwdriver.
  4. Apple Cinema Display M8149 USB Port Replacement: passo 4, immagine 1 di 1
    • Unplug the USB cable connector from the screen box.
  5. Apple Cinema Display M8149 USB Port Replacement: passo 5, immagine 1 di 2 Apple Cinema Display M8149 USB Port Replacement: passo 5, immagine 2 di 2
    • Using the PH 2 screwdriver, unscrew the two screws (4.85 x 2.94mm) on the USB ports.
Conclusione
Cal Poly, Team 10-41, Forte Spring 2011 Membro di Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,412
