Salta al contenuto principale
Andobil Easy Clip Car Mount Replacement
Cosa ti serve
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: passo 1, immagine 1 di 1
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: passo 2, immagine 1 di 1
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: passo 3, immagine 1 di 2 Andobil Easy Clip Car Mount Replacement: passo 3, immagine 2 di 2
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: passo 4, immagine 1 di 1
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: passo 5, immagine 1 di 2 Andobil Easy Clip Car Mount Replacement: passo 5, immagine 2 di 2
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: passo 6, immagine 1 di 1
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: passo 7, immagine 1 di 1
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: passo 8, immagine 1 di 1
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: passo 9, immagine 1 di 1
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: passo 10, immagine 1 di 1
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
Conclusione
Alexander Tavares
Membro da: 03/24/21
205 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 47
Tutti i Tempi: 1,660
