Salta al contenuto principale
Amana Freestanding Electric Range Burners and Rims Replacement
Cosa ti serve
  1. Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: passo 1, immagine 1 di 3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: passo 1, immagine 2 di 3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: passo 1, immagine 3 di 3
    • Turn the knob for the desired burner to full heat.
    • If there is an unusual amount of heat or no heat, continue.
  2. Amana Freestanding Electric Range Burners and Rims Replacement: passo 2, immagine 1 di 3 Amana Freestanding Electric Range Burners and Rims Replacement: passo 2, immagine 2 di 3 Amana Freestanding Electric Range Burners and Rims Replacement: passo 2, immagine 3 di 3
    • Turn off the burner and let it cool.
    • Remove the burner after it has cooled by grabbing the edge and carefully pulling the element at a slight upward angle.
  3. Amana Freestanding Electric Range Burners and Rims Replacement: passo 3, immagine 1 di 1
    • Clean the burner element end with a wire brush or a metal sponge.
  4. Amana Freestanding Electric Range Burners and Rims Replacement: passo 4, immagine 1 di 2 Amana Freestanding Electric Range Burners and Rims Replacement: passo 4, immagine 2 di 2
    • Take one end of the element and bend it by 3.2 mm to make better contact with the socket inside.
  5. Amana Freestanding Electric Range Burners and Rims Replacement: passo 5, immagine 1 di 2 Amana Freestanding Electric Range Burners and Rims Replacement: passo 5, immagine 2 di 2
    • Place the new burner rim in the space with the hole for the element.
    • Make sure it is aligned with the socket.
  6. Amana Freestanding Electric Range Burners and Rims Replacement: passo 6, immagine 1 di 2 Amana Freestanding Electric Range Burners and Rims Replacement: passo 6, immagine 2 di 2
    • Gently push the restored element through the hole into the socket.
  7. Amana Freestanding Electric Range Burners and Rims Replacement: passo 7, immagine 1 di 1
    • Turn the knob to full heat after all steps are completed to test that it is working.
Conclusione
Refer to guides on repairing electrical components of electric stove burners or seek professional help if the guide does not help solve the problem.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 42
Tutti i Tempi: 399
