Salta al contenuto principale
Alienware AW610M Scroll Wheel Replacement
Cosa ti serve
  1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: passo 1, immagine 1 di 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: passo 1, immagine 2 di 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: passo 1, immagine 3 di 3
    • Turn your mouse over with the scroll wheel facing down.
    • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
    • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
  2. Alienware AW610M Scroll Wheel Replacement: passo 2, immagine 1 di 2 Alienware AW610M Scroll Wheel Replacement: passo 2, immagine 2 di 2
    • Turn your blowdryer on a low heat setting.
    • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
    • Turn off your blowdryer, unplug the device, and set it aside to cool down.
    • Carefully peel off the stickers, and set aside as well.
  3. Alienware AW610M Scroll Wheel Replacement: passo 3, immagine 1 di 3 Alienware AW610M Scroll Wheel Replacement: passo 3, immagine 2 di 3 Alienware AW610M Scroll Wheel Replacement: passo 3, immagine 3 di 3
    • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
  4. Alienware AW610M Scroll Wheel Replacement: passo 4, immagine 1 di 1
    • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
    • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
  5. Alienware AW610M Scroll Wheel Replacement: passo 5, immagine 1 di 3 Alienware AW610M Scroll Wheel Replacement: passo 5, immagine 2 di 3 Alienware AW610M Scroll Wheel Replacement: passo 5, immagine 3 di 3
    • Disconnect any wire connections away from the mouse's circuit board.
    • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
    • Locate the scroll wheel placed in the gap of the mouse's backing.
    • My scroll wheel was crooked, most likely causing my issue.
    • Gently lift the scroll wheel mechanism out of the mouse's backing.
  6. Alienware AW610M Scroll Wheel Replacement: passo 6, immagine 1 di 3 Alienware AW610M Scroll Wheel Replacement: passo 6, immagine 2 di 3 Alienware AW610M Scroll Wheel Replacement: passo 6, immagine 3 di 3
    • Disconnect the scroll wheel sensor from the mouse backing.
    • Remove the old wheel from the plastic casing, and set it aside.
    • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
  7. Alienware AW610M Scroll Wheel Replacement: passo 7, immagine 1 di 3 Alienware AW610M Scroll Wheel Replacement: passo 7, immagine 2 di 3 Alienware AW610M Scroll Wheel Replacement: passo 7, immagine 3 di 3
    • Dip a cotton swab into hydrogen-peroxide.
    • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
    • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
    • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
Conclusione
Rana Ashour
Membro da: 04/04/23
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 114
Ultimi 30 Giorni: 424
Tutti i Tempi: 4,015
