Salta al contenuto principale
Acer Iconia W3-810 Speaker Replacement
Cosa ti serve
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: passo 4, immagine 1 di 1
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: passo 5, immagine 1 di 1
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: passo 7, immagine 1 di 1
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: passo 8, immagine 1 di 1
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: passo 9, immagine 1 di 1
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: passo 10, immagine 1 di 1
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: passo 11, immagine 1 di 1
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: passo 12, immagine 1 di 1
    • Remove the speakers from the device.
Conclusione
USF Tampa, Team 18-4, Blackwell Fall 2016 Membro di USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 419
