Salta al contenuto principale
Acer Iconia W3-810 Rear-Facing Camera Replacement
Cosa ti serve
  1. Acer Iconia W3-810 Rear-Facing Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Rear-Facing Camera Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Rear-Facing Camera Replacement, Rear-Facing Camera: passo 3, immagine 1 di 1
    • Lift the retaining flap fastening the ribbon cord to the motherboard using a plastic opening tool.
  4. Acer Iconia W3-810 Rear-Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the ribbon cord from its slot using a plastic opening tool.
  5. Acer Iconia W3-810 Rear-Facing Camera Replacement: passo 5, immagine 1 di 1
    • Remove the rear-facing camera from its slot and pose for a camera shot.
Conclusione
Adam Fierce
Membro da: 09/15/16
418 Reputazione
3 Guide realizzate
USF Tampa, Team 18-4, Blackwell Fall 2016 Membro di USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 445
