Salta al contenuto principale
2017 Kia Niro Headlight Replacement
Cosa ti serve
  1. 2017 Kia Niro Headlight Replacement, Headlight: passo 1, immagine 1 di 1
    • Open the hood of the vehicle and make sure it is secured to prevent injury.
  2. 2017 Kia Niro Headlight Replacement: passo 2, immagine 1 di 1
    • Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
  3. 2017 Kia Niro Headlight Replacement: passo 3, immagine 1 di 1
    • Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
  4. 2017 Kia Niro Headlight Replacement: passo 4, immagine 1 di 1
    • Place the cap in a location that is out of the way of your work area and where you can easily find it.
  5. 2017 Kia Niro Headlight Replacement: passo 5, immagine 1 di 1
    • Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
  6. 2017 Kia Niro Headlight Replacement: passo 6, immagine 1 di 1
    • Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
  7. 2017 Kia Niro Headlight Replacement: passo 7, immagine 1 di 1
    • Insert the new bulb by pushing it into the bulb compartment.
    • Turn the bulb clockwise until it is secure.
  8. 2017 Kia Niro Headlight Replacement: passo 8, immagine 1 di 1
    • Reattach the cap you previously set aside by rotating clockwise until secure.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Sydney Harper
Membro da: 10/23/20
229 Reputazione
1 Guida realizzata
Texas Tech, Team S9-G6, Cowan Fall 2020 Membro di Texas Tech, Team S9-G6, Cowan Fall 2020
TTU-COWAN-F20S9G6
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 96
Tutti i Tempi: 3,921
