Salta al contenuto principale
2003 Toyota Solara Tail Light Replacement
Cosa ti serve
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: passo 1, immagine 1 di 1
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: passo 2, immagine 1 di 3 2003 Toyota Solara Tail Light Replacement: passo 2, immagine 2 di 3 2003 Toyota Solara Tail Light Replacement: passo 2, immagine 3 di 3
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: passo 3, immagine 1 di 2 2003 Toyota Solara Tail Light Replacement: passo 3, immagine 2 di 2
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: passo 4, immagine 1 di 2 2003 Toyota Solara Tail Light Replacement: passo 4, immagine 2 di 2
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: passo 5, immagine 1 di 3 2003 Toyota Solara Tail Light Replacement: passo 5, immagine 2 di 3 2003 Toyota Solara Tail Light Replacement: passo 5, immagine 3 di 3
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: passo 6, immagine 1 di 2 2003 Toyota Solara Tail Light Replacement: passo 6, immagine 2 di 2
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
Conclusione
To reassemble the tail lamp, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
UC Davis, Team S2-G2, Cole Spring 2017 Membro di UC Davis, Team S2-G2, Cole Spring 2017
UCD-COLE-S17S2G2
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 60
Tutti i Tempi: 2,818
