Salta al contenuto principale
1999 Ford Contour Sun Visor Replacement
Cosa ti serve
  1. 1999 Ford Contour Sun Visor Replacement, Sun Visor: passo 1, immagine 1 di 1
    • Unscrew the visor from its housing.
    • The screws used are 1 inch sheet metal screws with a Phillips head.
  2. 1999 Ford Contour Sun Visor Replacement: passo 2, immagine 1 di 1
    • Disconnect any wires attached to the visor by squeezing the tab located on the power cable connector.
    • Reconnect the wiring before proceeding to the final step.
  3. 1999 Ford Contour Sun Visor Replacement: passo 3, immagine 1 di 2 1999 Ford Contour Sun Visor Replacement: passo 3, immagine 2 di 2
    • Completely remove the visor and replace with a new one.
Conclusione
Once all steps are completed, the sun visor will work as before.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,981
