AirPort/Bluetooth Board
2 Risposte Punteggio 1 |
My Optical Drive ejects discs after I insert them. |
2 Risposte Punteggio 3 |
My iBook is not booting, full speed fan, black screen |
1 Risposta Punteggio 2 |
Why my monitor is showing vertical lines and freezing after the boot? |
install OS X 10.5 from a bootable USB HDD? |
Ricambi
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Troubleshooting
Track down a number of hardware problems using the iBook G4 12" 1.33 GHz Troubleshooting Guide.
Upgrades
There are a number of components in the iBook G4 12" 1.33GHz can be cost effectively upgraded.
- Memory: The iBook G4 12" 1.33GHz has one RAM slot. You can add up to 1 GB of memory to your computer. Check out the RAM category, or check out our easy iBook G4 12" 1.33 Ghz RAM installation instructions.
- Hard Drive: Browse our hard drives and upgrade today.
- Optical Drive: The 24x Combo Drive allows you to read both CDs and DVDs and write CDs. Look through our optical drive category for additional optical drives. Install your new optical drive yourself, the easy way.
Identification and Background
Use the laptop identification system to help you identify your machine. iBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
