How to open the USB Rubber Ducky
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Background Information
The USB Rubber Ducky is designed to emulate a keyboard and can be programmed to execute a sequence of keystrokes, commands, and scripts on a targeted computer once it is plugged in. The device is often used in penetration testing and security assessments to automate tasks that would normally require manual interaction, such as exploiting vulnerabilities or bypassing security controls.
The device comes preloaded with a scripting language called Ducky Script, which allows users to write scripts that can be executed on a target computer in a matter of seconds. These scripts can be used to perform a wide range of tasks, including opening backdoors, stealing data, and executing payloads.
It is important to note that the USB Rubber Ducky, like any other tool, can be used for malicious purposes as well. It is illegal to use it without authorization on a computer or network that you do not own or have explicit permission to test.
